first mod
mxallred
first mod
Post by mxallred »
what mod should i do first to my spree??
'86 spree-35 mph on 50/50 c12 and premium
adark248
Post by adark248 »
put those little rainbow beads on the spokes that go "clinkclinkclinkclinkclinkclink" as you ride down the street, IMO.
burnt_toast
Post by burnt_toast »
start using regular gas.. :lol:
whats in ur sig is not helping one bit
projects galore :nerd:
chevyguyjay
Post by chevyguyjay »
engine swap lol :lol:
~2004 Geely Fashion~
keithw
Post by keithw »
What you do first depends on your goal with it. If you want to to last a long time and provide excellent service then spend time doing routine maintance described in the service manual. If you want it to be the fastest Spree on the planet and are willing to accept a very short life then throw it off of a tall bridge.
In my limited experience a couple of fairly simple mods with reasonable results and minimum risk are opening up the exhaust and smoothing the inside of the intake manifold.
Most important is to learn how to tell if you are running rich or lean and how to read spark plugs. Other than throwing it off of a bridge, about the quickest way to turn it into a piece of scrap is to run it too lean. Round up a couple spare jets, one step rich and one step lean from stock.
Also, you need to accept that anything you do to make it faster will shorten the life of it. The speed gods demand sacrifices.
keithw
Post by Kenny_McCormic »
Spree mods starting with what to do first.
1. Dill 2 exhaust baffles (shove bit up pipes tip, drill 2 plate)
2. smooth out intake pipe
3. mill head .020", be sure to use a new gasket and torque properly in an x pattern with a tourqe wrench to 9-10 ft/lbs
4. Port exhaust (raise a ring width), clean casting defects in the cases intake area
5. install a 1/2 inch auto belt instead of the stock metric one, this will up your gearing to take advantage of the take off power the above mods make.
6. enjoy your maxed out engine, top speed should be around 40 with good accel (belt mod)or 35 with crazy accel(factory belt).
Notes
Do a plug chop after doing any sort of modding.
Start with a motor that has good compression and a nice bore.
Before starting clean carb and muffler, replace air filter and spark plug.
Decarbonize engine while your in there.
If you take off the jug, have it rehoned and put in new rings while your in there if over 1000 miles.
[/u]
