Aero 50 project begins... is anything wrong?
Posted: Tue Jun 03, 2008 12:21 am
So I finally got my Aero 50 from a guy a few blocks over. He let me roll it out of his garage for $150. Then I rolled it half way home, stopping off at a friend's apartment because I was sweating through my shirt. I didn't think it was going to be heavy at all, but I was wrong. It definitely has some heft to it.
Here are some pics. Sorry for the horrible lighting, this house is a cave. I'll try to get some better ones tomorrow or something.
I don't know much about this scooter. My hope was that I could start off my project by getting input based on these pics. Does anyone see any horrible problems? Missing pieces?
Also, how hard to you have to kick a kickstart? Mine has some give, maybe an inch or so but then it catches. I kicked it a few times and one time I think it went a little further and made a slight gargling noise. But after that it's seized up again. If I put pressure on it the entire engine bobs. I don't know how to use the kickstart, what is the exact process?
It also has 5 year old gas in it, some of which I dumped out. Is there an easy way to drain all the liquids or do I have to take the gas and oil tanks out and then disconnect all the lines individually?
The engine is pretty dirty. The plastics look great from a few feet away, but if you get close enough you can see breaks around the bolts and some other cracks, scraps, etc. I think I'll probably paint it after I get it running. At some point somebody apparently repaired some of the plastics with what looks like old chewing gum. The front handlebar cover might be from another model. It doesn't seem to fit correctly. Maybe it's missing some tabs or something, any thoughts?
That's all I can think of right off the bat. I'm interested in hearing anything you want to share.
