Two questions...
Posted: Wed Jun 04, 2008 10:53 pm
Just have a couple questions....
1. When drilling baffles in the exhaust, I wasnt paying much attention apparently and I let it drill through the outside of the muffler under that plate thingie. What damage would this cause and will standard muffler tape be OK to cover up hole.
2. I decided to do away with the oil resevoir and just use premix, and Yes I ground the teeth off the pump and plugged the holes with vacuum plugs. I'm using a premium synthetic 2 cycle oil mixed with the gas...is this OK or is something better?
