I shot some carb cleaner on the grease and it turned the plastic white
good degreaser recomendations?
dukemartini
I need to clean the oil off of the inside of my plastics and i wanted to know if anyone had any plastic safe degreaser recommendations?
so...i don't want to go though that again.
87 Honda Elite S-BASKET CASE PROJECT
88 Honda SB50P-sold but not forgotten
Arcticcat440snopro
- BMX
What about brake cleaner? May not be plastic-safe but it's certainly a good degreaser.
Or get some "Goop" type hand cleaner in the round containers. That might work since it's suppose to clean grimey hands. Should be plastic safe since its safe on bare hands.
1985 Honda Gyro S (project bike, work in progress!)
1984 Honda Spree - Bought May 30, 2008 with 810.8 miles on it. (Sold with ~1600mi)
Others owned/rode/sold: '86 Helix trike, '07 Vino 125, '88 Elite 250
Dac wrote:Friends+your moped=BAD IDEA.
Brake cleaner is less agressive that carb cleaner. Try it someplace that doesn't show first.
A bucket of hot water, simple green, and a scrub brush has a lot going for it when it comes to cleaning grease off of things. I added a hot water tap on my back patio to feed my pressure washer. Soak something with simple green, let is soak for a while, then blast it with the pressure washer and it will come clean.
keithw
keithw
I use something called "Oil Eater" - comes in a spray bottle from the local auto parts store. It has a tendency to strip the gloss off old paint if you leave it on too long though. Its supposedly biodegradable and not too stinky.
For more delicate stuff you can use Go-Jo or Goop hand cleaner (without the pummice) on painted surfaces. Rub it on with a tooth brush, wipe most off with paper towel and rinse with water.
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
dukemartini
Grease remover?
Greased lightning get it at Home Depot, works real well.
-Curly
-Curly
I have a Honda Squash, purchased originally in Japan. I also have a Motobecane Moped.
- mopedman
Re: Grease remover?
* yea i have used that s*** beforCurly wrote:Greased lightning get it at Home Depot, works real well.
-Curly
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
