2001 elite 40 MPG!
2001 elite 40 MPG!
Just did the math for the first time (first gallon of gas) and im about 40 MPG, what am i doing wrong. Its de-restricted, i decarbonized the muffler. I max out at 27 MPH on flat road. I was having problem with my air screw being so loose that when i adjusted it, it would go back to fully seated position after about 30 seconds! I put some teflon tape on the threads and it stays put now, so I guess Ill run another gallon through and check the MPG again. Any suggestions on other things I can try?
dukemartini
I think its like 1.2 gallons (according to the gas pump at the gas station) But even so, I wrote down my milage before gassing up with 1.110 gallons, then took a of miles when i was near empty and filled up with .909 gallons. here is my math with 2617 miles at first fill and 2651 at fill today. 2651- 2617 = 34 miles using .909 gallons of gas, so.. 34 over .909 = 37.40 over 1 . So even 40MPG was an wrong Im getting 37.4 MPG correct?
- burnt_toast
Should definitely be better.. My modded Elite gets a consistent 42mpg with mixed riding, wot and 60+mph
Stock should be closer to 60mpg. Hows plug looking? A/F screw problem doesn't sound too good if it becomes fully seated that is richest setting and maybe why you're wasting more gas. Any air/exhaust leaks anywhere?
projects galore
wow..not good. do you see any leaks from letting the scooter sit in one spot? To help, I get 85 or so mpg on my '98 elite and it doesn't matter if I baby it or not its still in the 80's..synthetic gear oil and motor oil made mine just from the 60's to the 80's.
My air mixture screw is set somewhere between 1 and 1.5 turns out(as in 360 degree turns)
I just got done working on a 96 elite and it was set at 2 turns out(at 360 degrees)
Throttle on both was 2.5 turns out(at 360 degrees)
Honda Elite SA50-S
Stock motor, 9:1 gears, Kelli High speed pulley=a top speed of ?? Maxed the speedo out if that counts..average 45 mph
average 85 mpg
average 85 mpg
- burnt_toast
To get 35 or so, take off the plate on the variator and take the exhause off and drill out the washer..by drilling out the washer you'll not only go faster but will have better acceleration
Honda Elite SA50-S
average 85 mpg
average 85 mpg
