Do I have 2 differnt oils in '87 honda spree?
spurboy6
Post by spurboy6 »
I know I should have 2 cycle engine in oil tank under seat, but was reading in the manuel about using 10w-30 in the crankcase? My 87 spree has been sitting for about 15 years. Already cleaned tthe gas tank & carb, put a new plug, but would like to change all the fluids. Could you let me know how, and if there is more than one oil used in my spree.
Thanks.
mopedman
Post by mopedman »
you dont just use 2 cycle oil it has to be injector oil
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
Post by Kenny_McCormic »
The 10-40 is for the gearbox in the rear end, 2 stroke injector oil is for the 2 stroke engine.
justice4kurt182
Post by justice4kurt182 »
i used 10-30 in the tank under my seat and never had a problem untill i was told to use 2 stroke injector oil. changed the oil to the way too expensive yamaha 2 stroke injector oil then my engine destroyed it self...
mopedman
Post by mopedman »
justice4kurt182 wrote:i used 10-30 in the tank under my seat and never had a problem untill i was told to use 2 stroke injector oil. changed the oil to the way too expensive yamaha 2 stroke injector oil then my engine destroyed it self...
... not true.... you destroyed the engine by using 10w-30 and it just happened to finally die after you put the right oil in it, i wouldn't use that yamaha junk ether i would use gn2 form Honda or bel-ray
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
Exactly, the 4 stroke oil was probably holding the motor together.
