Do I have 2 differnt oils in '87 honda spree?
Posted: Fri Jun 06, 2008 12:22 am
by spurboy6
I know I should have 2 cycle engine in oil tank under seat, but was reading in the manuel about using 10w-30 in the crankcase? My 87 spree has been sitting for about 15 years. Already cleaned tthe gas tank & carb, put a new plug, but would like to change all the fluids. Could you let me know how, and if there is more than one oil used in my spree.
Thanks.
Posted: Fri Jun 06, 2008 12:51 am
by mopedman
you dont just use 2 cycle oil it has to be injector oil
Posted: Fri Jun 06, 2008 7:19 am
by Kenny_McCormic
The 10-40 is for the gearbox in the rear end, 2 stroke injector oil is for the 2 stroke engine.
Posted: Sat Jun 07, 2008 2:41 am
by justice4kurt182
i used 10-30 in the tank under my seat and never had a problem untill i was told to use 2 stroke injector oil. changed the oil to the way too expensive yamaha 2 stroke injector oil then my engine destroyed it self...
Posted: Sat Jun 07, 2008 3:41 am
by mopedman
justice4kurt182 wrote:i used 10-30 in the tank under my seat and never had a problem untill i was told to use 2 stroke injector oil. changed the oil to the way too expensive yamaha 2 stroke injector oil then my engine destroyed it self...
... not true.... you destroyed the engine by using 10w-30 and it just happened to finally die after you put the right oil in it, i wouldn't use that yamaha junk ether i would use gn2 form Honda or bel-ray
Posted: Sat Jun 07, 2008 1:06 pm
by Kenny_McCormic
Exactly, the 4 stroke oil was probably holding the motor together.
