Here is the story.
new plug, has spark
is getting gas and compression seems good.
battery is dead but doesn't matter.
starter motor wont work because the wiring is rigged to not need the key switch because it was stolen at one point but returned to the previous owner.
kick starter is not the greatest in the world as it gets stuck in the down position (probably weak spring plus messed up teeth) will sputter if tons of starting fluid is sprayed into air intake on carb.
all electrics worked last time it ran (minus blinkers which, when turned on blinked once then stop making you have to turn them on and off repeatedly).
when it died the engine shook vigorously then the rear wheel wouldn't turn so i assumed that it needed a new belt. but now that i have it apart the belt drive looks fine. replaced the engine with a 86 and swapped the rusty parts for the better looking ones off the '87 (magnito, coil, carb, gas tank and seat, rear turn signals and break light.) i basicly have a hybred 87-86 spree.
any ideas?
tools available:
deep socket set (8mm-14) and some random others
box wrench set (8mm-17mm) and equivalent in standard.
no multi meter or electric testing equipment.
'87 spree wont start.
justice4kurt182
anyone?
nice to know no one has anything to say about this.
- CharlotteSpreeRider
justice4kurt182
- justinnielsen01
