Standard spark plug size on an 89 Elite?
Scalpel
Post by Scalpel »
I've reached the stage where I need to remove the old spark plug and put in the new one on my 89 Elite. I tried the biggest metric socket I own, an 18mm, and it wasn't quite big enough. What size is the spark plug nut? 20mm? Bigger?
Post by Kenny_McCormic »
Its 11 or 13 sixteenths of an inch(cant remember), you need a special spark plug socket.
mopedman
Post by mopedman »
you can get a spark plug wrench at any auto parts store for under $10.00
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
Scalpel
Post by Scalpel »
mopedman wrote:you can get a spark plug wrench at any auto parts store for under $10.00
I've got a standard spark plug wrench, but that's not fitting...
Hey, is there maybe some sort of rubber boot around the plug? I can't see in there too well, but that would explain it not fitting any of my sockets.
mopedman
Post by mopedman »
it should fit in a standard spark plug
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
There is the plug wire and a rubber boot the seals the gap between the fan shroud and the plug.
Scalpel
Post by Scalpel »
Kenny_McCormic wrote:There is the plug wire and a rubber boot the seals the gap between the fan shroud and the plug.
Is the rubber boot removable without pulling off the shroud? The second bolt holding the shroud on is tucked behind the carb, and I don't really want to pull the carb off just to change a spark plug.
You just pull it off, its kinda obvious. do you have the sidepanels off?
BTW you have some false info in those pics in your sig, a chanisaws oil tank does not auto mix, you put premix in the gas tank and bar oil in the oil tank (for lubing the chain, this part is usually automatic). A chaninsaws oil tank has nothing to do with engine oil.
jstone
Post by jstone »
A sprees is 13/16. You have to have a deep well socket. The spark plug shouldn't be metric.
