Key + Ignition = stuck
Posted: Sun Jun 08, 2008 2:42 pm
by chrisdangerpants
My key is going into the ignition just fine, but it wont turn either way. It takes like 5 minutes of jiggling back and forth for it to finally get it to move from the off position. Any ideas?
Also, how much is a new one if its shot? Thanks!
Ps- i have an 86 spree
Posted: Sun Jun 08, 2008 2:58 pm
by monkeywrench
the key itself is wore out . the teeth are warring down making it not hit the tublers rite
Posted: Sun Jun 08, 2008 4:16 pm
by Kenny_McCormic
Its work out, the key and switch are probably both worn, take the switch to a locksmith and have him make a key that matches the worn out pins.
Posted: Sun Jun 08, 2008 10:39 pm
by Animal Chin
I lost the key for my '85 Spree and thought I would have to get another ignition. I took the lock from the trunk (very easy to get it off) up to the Honda dealer and they made me another key for $3. There is a code on the lock that they use to replicate the key.
Posted: Sun Jun 08, 2008 11:06 pm
by Kenny_McCormic
Strange, the trunk lock will open with anything you can jam in there, no pins.
Posted: Tue Jun 10, 2008 6:48 pm
by chrisdangerpants
my key is NOT worn at all, and my trunk opens just fine...
Posted: Tue Jun 10, 2008 8:12 pm
by Kenny_McCormic
Then you switch is either jamming or worn out. Try spraying some penetrating lube in there.
Posted: Wed Jun 11, 2008 6:11 pm
by SRSpree
Hey all, new to the forum. I'm trying to fix up my neighbors spree and it seems that someone has cut off the ignition module. Do I have to get a new one or is there any way I could get around this like hotwiring or anything.
Posted: Wed Jun 11, 2008 8:19 pm
by Kenny_McCormic
I would get a new one, these things are easy enough to steal already.
