Has anyone disassembled and reassembled the three piece crank?
How do you align the pieces to press it back together?
I need to replace the needle bearing on the large end of the rod. [/code]
Crank disassembly and reassembly
- burnt_toast
- justinnielsen01
It's in a 86 Spree. The scooter was not used for many years and the crank was frozen ( the piston and head are in good shape). Once the engine was broken lose, it could be manualy spun, you could the hear / feel bearing ginding. There appears the water (rust) line 3/4 " up in the crank. The rod bearing along with crank bearings were under this water line.
I'll look into a machine shop? I have seen some three piece cranks on small 2 cycle marine engines so I'll ask around there too.
[/img]
[/img]
- danmdevries
- BMX
A replacement crank shouldn't be much, and it'll be a new crank with new big end bearings and a new conn rod. I think I paid $120ish for mine. With all the bearings and the seals I rebuilt my bottom end for about 200 bucks. You might be better off doing that than bothering with the disassembly/reassembly of the crank. I have the press and skill to do it, but once that bearing is siezed, I don't trust the crank anymore, so personally it was worth the money for new components.
2004 Kymco ZX50
70cc kit, 19mm carb, chambered exhaust
Can we get a link for this? Does it show how to split a crank or just how to install a new aftermarket?justinnielsen01 wrote:there is a guy on youtube called diospeeddemon he has videos that show you how
Admin, Hondaspree.net
- justinnielsen01
http://youtube.com/results?search_query ... type=&aq=f
it is in a couple diffirent videos
