Bogs down and dies when accelerating
CypressRon
Post by CypressRon »
My 86 spree starts and idles good but bogs down and dies when accelerated. I changed the plug, new oil, gas, air filter, and cleaned the carb. It has been sitting up for over 15 years and was glad to just get it going. Now I need help in getting it to run at higher speed.
Post by Kenny_McCormic »
Clean muffler.
CypressRon
I removed the muffler and it is clear and open. I checked the exhaust port while I had it off and it is clean. Didn't help.
gobucks
Post by gobucks »
do a plug chop and make sure the mixture is right, mine did this.
CypressRon
All it will do is idle. Can you do the plug chop if it just idles? From what I've read you have to run it for a mile or more wide open.
Just rev it as high as possible on the stand for a few minutes, if its got a problem this extreme it will show up.
Motorcity
Post by Motorcity »
I'm having the exact same problem with my SE50P, I removed the muffler to eliminate that as the problem and it still does it. Starts right up without any problems and Idles properly, as soon as I hit the throttle it bogs down and dies. I checked my spark and it seems to be weak. The spark is not a healthy blue, I'm thinking it's the coil or the CDI unit.
mopedman
Post by mopedman »
Motorcity wrote:I'm having the exact same problem with my SE50P, I removed the muffler to eliminate that as the problem and it still does it. Starts right up without any problems and Idles properly, as soon as I hit the throttle it bogs down and dies. I checked my spark and it seems to be weak. The spark is not a healthy blue, I'm thinking it's the coil or the CDI unit.
were you at in michigan, i will help you with it if your close, the M.M.M. is always trying to help other riders and make new friends
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
Motorcity
Post by Motorcity »
I appriciate the offer and will definately take you up on it if I can't get it going. I just got power back tonight from last sunday's storm and have been itching to get the elite working again, I've been tinkering with it using a latern, lol. I'm in Bloomfield hills, bout 30 mins. from Fraser (used to date a chick from Fraser).
The reason i'm thinking it's because of weak spark is when it's idling the weak spark is giving enough spark to fire the strokes but when more gas is dumped into the cylinder it bogs it down, too much fuel, not enough spark. I checked compression and it's pulling a solid 116 PSI with a high quality tester...
stillspeeding
Post by stillspeeding »
Cold start tune, as soon as you start the engine turn the fuel screw out slowly while revving the throttle, the bog may go away but it may not work on auto chokes but works on manual choke carbs.
Can't afford speed then stay away from it!
mopedman
Post by mopedman »
The reason i'm thinking it's because of weak spark is when it's idling the weak spark is giving enough spark to fire the strokes but when more gas is dumped into the cylinder it bogs it down, too much fuel, not enough spark. I checked compression and it's pulling a solid 116 PSI with a high quality tester...[/quote]
well i have a 1995 elite s, if i ride it over to your house we can just try the coil off my bike, it sounds to me like its getting tooo much air.
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
Motorcity
Post by Motorcity »
It's very well possible, I don't have an air filter for it :shock: the old one just crumbled in my hands, I have one on order and it should be here by monday or so. Hopefully thats it, i'll update as soon as I get the new one. MC
Motorcity wrote:It's very well possible, I don't have an air filter for it :shock: the old one just crumbled in my hands, I have one on order and it should be here by monday or so. Hopefully thats it, i'll update as soon as I get the new one. MC
Thats your problem.
CypressRon
I ran it best I could and pulled the plug. I was a new plug and I ran it for maybe 10 minutes off and on due to the dying. When I pulled it it looked like half the tip was black and the other half clean. The black looked a little oily but no oil on the white half. I didn't notice when I put the plug in but it looked like the middle part (where the spark comes out) was not centered in the plug. Could this be a problem?
Spreebie
Post by Spreebie »
I had the exact same problem with my '86 Spree which had been sitting for twenty years. Just fixed it today. There is a brass looking tube the throttle needle goes into. It is under a jet which screws into the carb. You have to take the carb off, take the float bowl off, unscrew the jet and push this tube out of the bottom of the carb. There are eight (I think) holes in the side of the tube you need to make sure are cleaned out. I then sprayed carb cleaner through the holes and the tube. The carb sitting in carb cleaner overnight did not clean them.
One of the tech articles here say not to use anything metal to push the tube out. I used a small wooden dowel I sanded down to the right size. The bike ran great after reinstalling. Hope this helps.
New to the Spree world- '86 Spree 102 miles
'86 Spree 915 miles
