gobucks
Posts: 185 Joined: Thu May 15, 2008 9:29 pm
Post
by gobucks » Thu Jun 12, 2008 10:46 pm
my engine dies out at wot, it's really annoying when your bike can't show its full potential, does anybody know what this could be?
Posts: 4957 Joined: Sun Apr 16, 2006 11:51 am
Post
by Kenny_McCormic » Fri Jun 13, 2008 10:46 am
Its either lean or rich. if you hold your hand over the air intake holes and it runs better its lean, if it runs without an air filter/cover its rich.
gobucks
Post
by gobucks » Fri Jun 13, 2008 6:40 pm
i just covered the air intake hole in the air cleaner housing and it runs great!, so, what do i have to do to fix the lean fuel mixture ( i have a stock 68 jet), and the carb has been cleaned about 5 times.
mopedman
Posts: 1213 Joined: Mon Jul 23, 1973 10:24 am
Post
by mopedman » Fri Jun 13, 2008 6:43 pm
check for air leaks...... is your air filter oiled
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
Post
by Kenny_McCormic » Fri Jun 13, 2008 6:45 pm
Do you have an air filter?
gobucks
Post
by gobucks » Fri Jun 13, 2008 6:59 pm
i have an air filter and i just oiled it, where do you think a probable place for an air leak would be at?
mopedman
Post
by mopedman » Fri Jun 13, 2008 7:02 pm
the tube going from the air box to the carb. make sure it is on good
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
gobucks
Post
by gobucks » Fri Jun 13, 2008 7:46 pm
hi, just checked hose to carb and its great, i unplugged the auto choke wire and the bike runs great, is there a permanent fix for this?
Post
by Kenny_McCormic » Fri Jun 13, 2008 10:25 pm
Plug the choke back in and fix it the correct way, use an unlit propane torch to check for leaks.
CypressRon
Posts: 6 Joined: Thu Jun 12, 2008 11:38 am
Post
by CypressRon » Sat Jun 14, 2008 3:17 pm
How do you check for air leaks with an unlit propane torch?
mopedman
Post
by mopedman » Sat Jun 14, 2008 3:57 pm
u blow it on the the air box, intake, air hose.... any were you think it is leaking.... if the engine starts to rev up when you go over a spot that is were it is leaking
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
gobucks
Post
by gobucks » Sat Jun 14, 2008 6:36 pm
i can't find a leak with the torch, the engine doesn't even rev up when i put the torch straight into the air filter box. Is there anything else that i can do?
