Proper jet size
Posted: Thu Jun 19, 2008 11:23 pm
by shortcal
2001 elite. new variator/weights/r1 muffler/ oil pump is tied open. Now Im not 100% about this whole jet business. Runs well hits a little over 40. Im assuming it needs to be bigger perhaps someone could enlighten me if im wrong? what size should it be at? Is my engine gonna be ok without rejetting? I would personally rather not get in there and tinker with the carburetor if i dont have too.
Posted: Fri Jun 20, 2008 12:47 am
by mopedman
with a set up like that i would get a performance air filter and a set of gears and up jet it and you will be good to go
Posted: Fri Jun 20, 2008 2:11 am
by burnt_toast
mopedman wrote:with a set up like that i would get a performance air filter and a set of gears and up jet it and you will be good to go
I would disagree. stock carb will not handle open filter very easily, usually end up boggy with little gain. small upgear wouldn't be a bad idea though
With an R1, you're probably okay, but do some plug chops. Check tech docs or search for how to do it, very easy.. then you'll know if you need to upjet or not.
Posted: Fri Jun 20, 2008 11:27 am
by Kenny_McCormic
Yea, do plug chops, you dont want to run it lean and melt the engine.
Re: Proper jet size
Posted: Fri Jun 20, 2008 11:45 am
by happyman
would do the airbox mod and then slap in a 90 main with that pipe. a 9.0 gear will run about 50 mph and it will get decent mpg also.
shortcal wrote:2001 elite. new variator/weights/r1 muffler/ oil pump is tied open. Now Im not 100% about this whole jet business. Runs well hits a little over 40. Im assuming it needs to be bigger perhaps someone could enlighten me if im wrong? what size should it be at? Is my engine gonna be ok without rejetting? I would personally rather not get in there and tinker with the carburetor if i dont have too.
Posted: Fri Jun 20, 2008 4:09 pm
by shortcal
where might i be able to get a larger jet? My honda dealer is saying the highest he can get me is a 78 and I dont have a drill or bits or anything to drill a larger one
Posted: Fri Jun 20, 2008 11:31 pm
by keithw
Here is what I did. Take the part number for the largest jet you can find. Looking at the number you can see where the size is coded. Change that to the size you want and google the number along with "honda". I found a mower place that had 80 and 85. Some of the Honda power equipment use the same style jets in different sizes than came in the bikes. For my Pal (Spree sort of thing) I've found 63, 65, 68, 70, 75, 80 and 85. I found part numbers for smaller ones but I'm not going that way. Gotta love that internet.
keithw
Posted: Sat Jun 21, 2008 8:30 pm
by tru72
i posted a link one time to a place that i buy my metric drill sets from.
They are perfect for jets!
aloha
D
Posted: Sun Jun 22, 2008 7:05 am
by noiseguy
There's info in adv tech docs here on drilling out jets if you decide to go that route.
