1985 Spree, gas gauge needle always shows past F as in Full, seems to be stuck. Sending unit seems to be okay, I pulled it out and had a quick look at it, but I'm not sure which end to check first. Sending unit failure or maybe the gauge needle itself is stuck? Tips, hints, clues welcome, thanks.
Yeah, I did think I was getting some pretty good milage until I had a look in the tank! I'll check wiring on the gauge end, as the sender unit seems to be fine (and easier to inspect!).
