Idle noise...
Posted: Tue Jun 24, 2008 11:16 pm
by Burgleflickle
I'm having trouble with idle noise on my 88 sa50. She still starts on the first kick, but just gives a ringing, grind noise. I have isolated the sound to the kickstart. When I pull out on the kickstart pedal lightly, the sound gets very soft. I'm wondering if I should be looking at pinion gears, or just check the driven gear and lube what I need to. If someone could please help, I'd appreciate it. Thanks guys.
Posted: Wed Jun 25, 2008 1:45 am
by Kenny_McCormic
Not returning properly, pull it off and have a look/lube it up (soak it in WD40).
Posted: Wed Jun 25, 2008 7:57 pm
by Burgleflickle
I pulled it apart and oiled it. It sounded fine until the snap ring moved on it during use. The kickstart pedal dropped down as well when I drove it around the block... Possible to just put washers in and shim the kickstart on the outside of the cover?
Posted: Wed Jun 25, 2008 9:33 pm
by Kenny_McCormic
Could be a missing washer or something, check a break down parts diagram.
Posted: Fri Jun 27, 2008 11:16 pm
by Burgleflickle
I have it fixed. It was just like you said. I put a washer in, and I'm good to go.
Posted: Sat Jun 28, 2008 2:18 am
by Kenny_McCormic
Cool.
