Variator restrictor question (pic)
Motorcity
Post by Motorcity »
I just want to make sure I have it all right before I put it back together. I removed the pulley and removed the plate thats held on with the 7mm screws. I've read all the tech documents but just to clarify before I put it all together. I remove the plate and screws, I'd imagine that I remove the O-ring as well. then I just put it all back together (without the plate, O-ring and screws). The variator is greased, won't the grease sling around inside of the case maybe contaminating the belt?
evilone
Post by evilone »
looks like you have the same non-restricted variator as me, can't do anything with it, someone mentioned a different ramp. Or get the high speed pulley kit from vtcycles (in stock).
Dac
Post by Dac »
that one is not restricted.
It is pointless to remove anything. But so you know, the ring to the right is what is restricted on some bikes. But not on your.
Remove the grease. it will improve your mid range.
Honda put it in there so it will get to speed slower.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
Post by Kenny_McCormic »
http://www.scootertherapy.com/Eliteclutchpage.html What a restriction plate looks like. Like Dac said, clean the grease out, maybe leave a THIN coat on the moving part contact surfaces but thats all.
mopedman
Post by mopedman »
what kind of gun you got there, it looks allot like mine
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
Motorcity
Post by Motorcity »
Thanks for the replies, it didn't look right to me thats why I was second guessing it. I will call VTcycles tomorrow about a high speed pulley.
Mopedman
The pistol is an HK USP-9
Mc
chevyguyjay
Post by chevyguyjay »
in the first pic. the one u have is the pully on the right. thats the SE50P model. u want the SE50S model ramp like the one on the left. the second pic shows the differences to. notice the ramps? hope this helps. :wink:
~2004 Geely Fashion~
mopedman
ok
Post by mopedman »
ok it looks allot like mine, i got a Spring field XD 9mm sub compact
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
maddog
Post by maddog »
both of those pulleys are shot.
Elite1998
Post by Elite1998 »
Dac wrote:Remove the grease. it will improve your mid range.
Keoni told me the grease will make the rollers last longer and doesn't affect the speed. I say lightly grease them..too much would probably slow it down
Honda Elite SA50-S
Stock motor, 9:1 gears, Kelli High speed pulley=a top speed of ?? Maxed the speedo out if that counts..average 45 mph
average 85 mpg
solstice
Post by solstice »
Does anybody know if a 1985 NB50 Aero have a restrictor plate?
It might, have a look.
burnt_toast
Post by burnt_toast »
Correct, does not affect speed or acceleration only prolongs roller life. Come on Dac gotta know the facts first :lol:
Roller inertial force >> grease damping resistance
projects galore :nerd:
justinnielsen01
Post by justinnielsen01 »
i got a high speed variator and it has no grease you just gotta get new rollers a bit more and removing the grease like dac said will help
Dac
Post by Dac »
then how come all new bikes that honda and yamaha make dont come with grease in there?
i just tore apart a 07 honda metro and it was bone dry.
