questions about dio motor
Posted: Mon Jun 30, 2008 11:14 pm
So im starting to think i want to drop the money to swap a dio into my spree. I've been doing the research, but i can't find too many threads with good info in them. So i thought i would post some of my questions.
first off. Everyone says all you need is to worry about mounting it up and changing the kickstand. But im assuming i need the exhaust and carb off the dio? after i get it going, with a stock motor. Im wondering how fast will it be. I read the top speed will still be around 35, but will it blow a stock spree away as far as acceleration? What all mods can you get big gains out of. Im not looking to dump money into this project just for the sake of spending money. I only want mods that will get big gains. That said, is all i need a big bore kit and gears? I read in the "adding gears sticky thread" that you need to do a 70cc big bore kit before you can do gears or you won't have the power to make a difference, but does 20cc really make that big of a difference? Whats the acceleration like on a dio that does 70mph? Do i have a choice in gears, because i think 70mph is a little excessive for a spree.
well i hope someone can answer my questions. thanks
