Intake
matt
Intake
Post by matt »
How good dose it work when you file the intake. Any disavantages?
Ducktape fixes everything.
vette76
Post by vette76 »
about 4-5 mph more.+ more power. no disadvantages unless u are clueless and mess it up.
87' spree (SOLD
12' wrx
matt
Post by matt »
I have a second intake of a 84 that should be the same righ? I will try it on it then put it on my 86.
Should be the same. I concentrated on the upper portion... Anyone else?
matt
Post by matt »
Can anyone post pics of theres? I dont really see no restrictions on mine. I will post a pic can some one open it in paint and make an arrow pointing to where you where filing?
matt
Post by matt »
Im charging my camera and ill take some pics
matt
Post by matt »
vette76
Post by vette76 »
www.freewebs.com/spreepics
go to performance parts.
87' spree (SOLD
12' wrx
matt
Post by matt »
In that pic it sortof hard to tell what you did. mine is a 84 and it looks like it could flow all the that the carb could and i dont see nothing to file.
matt
Post by matt »
Well i took my dremal tool and cleaned it up and rounded the inside edges a little. spend about 3 min doing it. Here are some pics http://photobucket.com/albums/v736/matt ... 5d084a.jpg
http://photobucket.com/albums/v736/matt ... ure019.jpg
Sorry my camera sucks for close up.
If they need my password its 951207
matt
Post by matt »
i used a dremal to work on the intake and finaly put it on then drove for a while. it had a top speed of 24mph going uphill or downhill. then thought maybe i would have to adjust the carb. but then it bogs out and i cant get it go back to normal. and i do know how far to turn it. its all correct. its dark out now but tomorrow ill swap the stock intake back on see what happens.
That's what the mod should look like. Sounds like you're having other carb problems now though.
matt
Post by matt »
Went back out and thought i would try it again and it seemed to run normal until i got reved all the way up for about 5 seconds and took off and it bogged out again. the longer i wait the more it seems to go. think its starving for fuel cause of the petcock valve or carb issues. everything worked fine until i switched intakes. and i didnt touch anything on the carb when i switched the intake i just undid the 2 bolts holding it on and let it hang there as i switched them.
peter1sp
Post by peter1sp »
vette76 wrote:about 4-5 mph more.+ more power. no disadvantages unless u are clueless and mess it up.
Vette Can you post a step by step... I am not sure what to file. Also, how much do you weigh? Did your gas mileage drop much? If so, how much? I have taken the intake off and there is a little area that is raised. I don't have a digital camera, or else I would post.
Does the bike still bog out at the start. The only reason I would want to file the intake would be to gain more low end torque, but I don't want to mess it up.
Thanks.
1981 CM400 C... Former Rides: 1986 Honda NQ50
vette76
Post by vette76 »
not sure on gas mileage. not much of a difference. inside the carb side u will see a machined circle that is restricting air/fuel flow. file out this restriction. it did help with all around performance.
87' spree (SOLD
12' wrx
