How do I remove the rear wheel?
Posted: Thu Jul 10, 2008 5:55 pm
by domromer
I'm about to order some slick new tires for my Aero. Removing the front seems pretty straight forward. unscrew the brake cable and loosen the nuts on the axel.
The rear has me scratching my head. I can see the axel and nut on the right hand side, but the left side is a big case were I imagine the drive belt and gears would be. How do I go about removing the wheel?
Posted: Thu Jul 10, 2008 6:13 pm
by mopedman
you take nut off, pull on rim
Posted: Thu Jul 10, 2008 6:14 pm
by Base4life
I don't really no, But try removing that and you should have a better look at it. It is not hard to remove.
Posted: Thu Jul 10, 2008 6:21 pm
by domromer
mopedman wrote:you take nut off, pull on rim
Does the axel not come out?
Posted: Thu Jul 10, 2008 6:23 pm
by mopedman
nope you do not need to take it out, you just put a block of wood in the rim to hold it in place then hit it with and impact gun, or a socket wrench and a lot of force
Posted: Thu Jul 10, 2008 8:15 pm
by justinnielsen01
that works or i just put the park brake on and take the bolt off with a wrench. then undo the park brake and pull it off
Posted: Thu Jul 10, 2008 10:17 pm
by nparks
justinnielsen01 wrote:that works or i just put the park brake on and take the bolt off with a wrench. then undo the park brake and pull it off
I got the bolt off, but the engine case is in the way. I've been trying to get the gearbox apart but I think someone used RTV or gorilla glue as a gasket haha.
Posted: Fri Jul 11, 2008 7:37 am
by GIJoeBob
nparks wrote:justinnielsen01 wrote:that works or i just put the park brake on and take the bolt off with a wrench. then undo the park brake and pull it off
YOU DON'T TAKE THE GEARBOX OFF!! The wheel just slides off the axle on the right side of the scooter.
Posted: Fri Jul 11, 2008 10:58 am
by noiseguy
Wheel is probably just stuck on the axle. Hit it with a rubber mallet a few times to loosen it.
Seriously, does anyone bother reading the manuals anymore?
Posted: Fri Jul 11, 2008 11:02 am
by shortcal
no offense but the manual really isnt that helpful if you arent familiar with mechanic stuff before hand.
Posted: Fri Jul 11, 2008 2:02 pm
by mopedman
you have to remove the muffler take the nut off and pull that is it
Posted: Fri Jul 11, 2008 3:08 pm
by nparks
GIJoeBob wrote:nparks wrote:justinnielsen01 wrote:that works or i just put the park brake on and take the bolt off with a wrench. then undo the park brake and pull it off
I'm changing the gears to 7.5:1 haha
I'm not that big of a noob.
Posted: Sat Jul 12, 2008 3:30 am
by domromer
Does the muffler swing out of the way somehow? Or do I have to unbolt it to remove the rear wheel?
Posted: Sat Jul 12, 2008 8:04 am
by GIJoeBob
domromer wrote:Does the muffler swing out of the way somehow? Or do I have to unbolt it to remove the rear wheel?
You have to take it off all together. But it is not that hard, just 4 bolts.
