83 Aero issues
Posted: Sat Jul 12, 2008 5:18 pm
by xxotaruxx
I haven't had my Aero very long and it hasn't run since I have gotten it, but I finally rebuilt my carb and got everything cleaned up today and after reinstalling everything, it wont start. After reading up, I found a suggestion of pouring some fuel where the spark plug goes and then reinstalling the spark plug to see if it would start. After a few tries, it started then stopped after that fuel was burned. I am getting fuel into the bowl of my carb but apparently none is being drawn into the cylinders. Any idea?
Posted: Mon Jul 14, 2008 7:18 pm
by GN Racer
Not a big deal. Disassemble the carb and clean out all of the passages; there is a clog somewhere.
You'll be fine.
Posted: Mon Jul 14, 2008 9:35 pm
by Kenny_McCormic
Try choking it with your hand, I though my spree had a full bowl but it didnt and the bystarter wasnt working because of it. if that doesnt work clean the carb.
Posted: Tue Jul 15, 2008 10:01 am
by paz
Have you re-installed the complete air box and filter before you tried to start it. It won't start if it has too much air. Make sure the air filter is oiled that also reduced air flow.
