need help fast: How to Press the Bearings back into the case
Posted: Wed Jul 23, 2008 12:32 pm
ive been waiting for over 2 weeks for this new bearing and i thought i had it all figured out. I thought youd just get the crank set into the cases and start threading the bolts in and it would just press it self together.
Well i am having super problems with it. I cant seem to get it to tap more than about 1/64" into each side of the case. And i am afraid if i try to thread it together like i thought then i will just strip the case.
I sanded each slot on the case smooth with 360 sand paper so there are no nicks or burrs. I also used some GN2 to help them slide easier. i dont wanna wreck anything, and i cant figure it out!
HOW DO YOU PUT THIS BACK TOGETHER??
