84 Spree doesnt want to run today
greenninja37
Post by greenninja37 »
well last week it was running great 30 miles an hour full bore ,,,idlin runnin strong,, i just put a brand new air filter in... last night it was runnin but would bog down every now n then.....today it doesnt even want to start up. the guy i bought it from said it was just sitting in his garage for a few years, so i still need to clean the carb out, but what puzzles me is last week it ran strong and now it doesnt want to start.
Think i might need a new plug considering its been sitting a few years?
New to the moped scene.
Proudly riding a White 84 Spree
dr.ona
Post by dr.ona »
Drain the gas tank and clean the filter.
Put new gas in it.
Drain oil and change oil to Honda GN2 oil.
Check gear oil.
New spark plug.
That would be a good start.
See what happens...I would eventually rebuild the carb.
After awhile I would de-carbonize your muffler.
Double check your tire pressure while your at it.
"I can't drive......35!"
gobucks
Post by gobucks »
oil the air filter, could be running lean, do a plug chop.
Post by Kenny_McCormic »
Clean carb and oil airfilter, dirt gets in the carb and when it floats in a hole bad things happen.
PimpinSpree
Post by PimpinSpree »
sounds like you need to clean your carb
if i were to get a new scooter a short list of things i would do to make it reliable
change spark plug
drain gas tank and add fresh gas
change fuel lines
add an inline fuel filter
clean carb and put new gaskets in it
clean out the muffler
decorbonize the exhaust port
start with cleaning your carb and changing the spark plug..... and new gas
greenninja37
yes thanks for the great advice, well i got it with no gas in it so it has fresh in it already... but im going to have to drain and fill the oil, ill also invest in a plug,, then if no go ill clean the carb and get around to decarbonizing the muffler eventually....a plug chop is just changing the plug right? and when i clean the carb should i just take it apart and soak it in somthin like WD-40? if somone could explain it that would be great!!
Thanks for the fast help also
You dont need to drain the oil unless it isnt 2 stroke injector oil.
greenninja37
well im sure its the right oil but its also been sitting for a while
PimpinSpree
a plug chop is where you run it at wide open throttle for a stretch, shut it down right away, then either then, or when it cools a bit, take the plug out and check the color of it
you need to use carb cleaner on the carb, wd-40 wouldn't work very well. Theres a how to in the tech documents. Make sure not to get carb cleaner on the gaskets, and make sure you don't poke anything in the little holes
oil like that doesnt go bad on the shelf.
greenninja37
ohhh alright so im set with the oil, still gotta get a plug and rebuild carb n see if it starts, im kinda worried if i take apart the carb i might screw somthin up though.
Just go slow and be gentle, dont stick anything in the holes.
