been
Posted: Sun Jul 27, 2008 1:33 am
by nightwolf1772
I j
Posted: Sun Jul 27, 2008 2:04 am
by Kenny_McCormic
If it was left outside the cable is junk.
Posted: Sun Jul 27, 2008 7:16 pm
by nightwolf1772
Al
Posted: Sun Jul 27, 2008 9:41 pm
by hondaman
As long as it is running good and not bogging down the answer is maybe.
You may want to check your tires and inflate them to proper psi.
A new spark plug would not hurt. Check your air filter and make sure its clean and not falling apart. A new one would be better. Also change the gear oil back by the rear tire and put fresh oil in there as well.
Posted: Mon Jul 28, 2008 12:27 am
by nightwolf1772
were is the air filter located? My dad was the one who normally worked on it but I m wating to learn about all the stuff myself
Posted: Mon Jul 28, 2008 7:04 pm
by hondaman
Keep looking . You will find it. Hint-- its under a cover with a hose running to it.
Posted: Mon Jul 28, 2008 9:47 pm
by Kenny_McCormic
Near the rear wheel.
Posted: Mon Jul 28, 2008 10:50 pm
by nightwolf1772
alright
