Page 1 of 2
SA50PS needs more top speed
Posted: Sat Aug 02, 2008 1:39 pm
by gobucks
i already derestricted it , decarbonized it, new rings, and plug.
Posted: Sat Aug 02, 2008 11:55 pm
by Dac
how fast it go now?
how much you wanna spend?
what year is it?
Posted: Sat Aug 02, 2008 11:59 pm
by Kenny_McCormic
9:1 gears, high speed pulley kit
Posted: Sun Aug 03, 2008 12:21 pm
by gobucks
its a 95, goes about 30 mph, and would like it to go about 40.
Posted: Sun Aug 03, 2008 12:56 pm
by Kenny_McCormic
Call up VT cycles and order 9:1 gears and a high sped pulley kit.
Posted: Sun Aug 03, 2008 1:35 pm
by gobucks
would the napa machine shop be able to pull the gear off so that i can switch them out?
Posted: Sun Aug 03, 2008 1:42 pm
by Dac
anyone with a press can press them for you.
9:1 gears and a highspeed pulley kit from VTcycles cost $105. (after shipping)
Put on a completely stock elite Sr you can go 47-50mph.
Its a good set up because you keep your stock cylinder, meaning no break in. And you can hold it WOT for long times without worrying about overheating.
Its also good because it wont make your bike any louder. In the case of my friends Sr, he had to keep it quiet because of the place he lives. This was the perfect set up.
Posted: Sun Aug 03, 2008 1:50 pm
by gobucks
would a SA50PS have the same top speed results?
Posted: Sun Aug 03, 2008 2:08 pm
by Dac
if its unrestricted it should have the same results yes.
by Kenny_McCormic
A PS? P is the slow one, S is the fast one, P has a less aggressive drive ramp and a straight pipe (doesnt get bigger as it gets to the muffler) exhaust.
Posted: Mon Aug 04, 2008 10:32 pm
by gobucks
under the seat it says SA50PS, is there any other way to know what model it is, possibly by the vin number.
Posted: Mon Aug 04, 2008 10:49 pm
by gobucks
i looked into it and i found some elites called an "SA50P Elite S", so its a SA50P, i checked by the vin, how much slower is the P model than the other?
Posted: Mon Aug 04, 2008 11:01 pm
by Dac
the elite S has the washer in the top of the tail pipe, but they have a way better pipe then an Sr.
Also, im not sure where kenny gets his info, but i can tell you, Comparing my elite S to my friends Sr. The S has a better pipe, but the S also has the plate on the variator.
Personally as the for the ramp, i believe there the same, but im not 100% sure.
Posted: Tue Aug 05, 2008 2:45 am
by maddog
DAC, you are dead wrong on this one, the sr model is the unrestricted version of the S-model, yea i build non -RIP scoots lol
Posted: Tue Aug 05, 2008 10:42 am
by gobucks
so, if i have the "SA50P Elite 50 S" is this the faster one or the slower one?
