Polini Big Bore bogging after half throttle
Posted: Sun Aug 03, 2008 5:26 pm
96 Honda Elite SA 50
I have installed a Pollini Corsa 72ccBig Bore Kit with stock carb and stock exhaust, stock air filter and a high speed pulley. I installed the larger jet that came with the kit, but I do not know the size of the jet.
When I run the throttle, the scoot runs fine up to about half throttle, but once it goes past half throttle, it is bogging down, but not cutting out. It just about runs at top speed just beyond half throttle. I am running at about 250 degrees most of the time, which I have been told is cold. I have done a plug chop and the plug looks good.
Am I running cold at 250? Does it seem like I am running rich above half throttle? What do you guys think about a smaller jet?
I appreciate the input.
