first off, excuse the crappy welds, its due to the welder i used. I borrowed a cheap $100 110 ac arc welder. Im a decent welder, but this thing is near impossible to make any welds that look good. I burned a couple holes (did my best to fill them) because i turned the heat up to make sure it penetrated good
My motor mount welded up. 1 1/2" thick piece of strut channel, with a bolt and a washer welded on
wet tshirt and towel over overthing, worked good, nothing caught on fire
motor mount welded on, not really happy with it, but its strong, just ugly, i covered it in jbweld to fill in all the little nooks and crannys. REALLY REALLY wish i would have bolted it on
torn apart, replacing the brake cable, no kickstand yet, getting ready to weld the kickstand on
didn't learn my lesson welding the mount on, so i welded the kickstand on. IT had too much flex so it needed a bolt welded in to stabalize it. Worked awsome, im fairly happy it.
heres the finished kickstand, with it down
here it is with it up
and heres a shot of the wiring splices, Just had to cut off the se50 harness, and crimp on either male or female barrel connectors
