I purchased a 1986 honda spree about a month ago and the electric starter hasn't worked from day one. The kick start works fine, but electric starter won't work. The battery is works and runs the other things fine. There is no click when i press the starter button either. Any ideas of what the problem is?
Thanks in advance for any help!
Electric Starter Problem
Get out a multimeter and some alligator clip jumpers. Does the relay get 12 volts? When you hit the start button does the starter get 12 volts? If the relay wont switch will it switch if you hotwire it (put 12 volts to the trigger and round to the other little wire)?
You can also test the relay by putting a screwdriver across the contacts (on the starter circuit side, not the switch side) to short it with the ignition key on. If the relay is bad the starter will turn over.
Clive.
Clive.
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
dei4life38
Just a suggestion
If you have your service manual for the machine, check the chapter on the ignition system and back track the problem from start to finish. I did this on an elite and determined my problem was the cdi.
