Reed valves
Reed valves
what are some of the symptoms of bad reeds, i was wondering if low compression is one of them, because it am getting about 90 psi of compression and have replaced the rings, head and base gasket with no improvement, are the reed valves a probable cause for the low compression?
Hello Im new here, just wanted to say Hi
Also this may sound dumb... but where are the Reed Valves at?
I just picked up a 85' spree and have been reading thru some posts and it boggs out when I give it gas but ides fine gonna do all the stuff Iv read like clean carb an fuel filter an exhaust but if it might be bad reed valve were is it at? Oh yeah an when I drained the oil there was some nasty smelling stuff in there...
Sorry and Thanks
Sorry and Thanks
its not the reeds.Spiderlad wrote:Hello Im new here, just wanted to say Hi![]()
Sorry and Thanks
If the reeds are bad, your bike will be just about impossible to start.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
Thanks for the reply
where are they at for future reference?
Thanks again
Thanks again
Dac wrote:its not the reeds.Spiderlad wrote:Hello Im new here, just wanted to say Hi![]()
Sorry and Thanks
got it going so it doesnt bogg out, but its somkes a lot from the exhaust and I mean ALOT!!! As I said before the person I got it from had some smelly funk in where the oil should be I drained it (an put in honda 2stroke oil) an cleaned the oil filter air filter and was gonna clean the carb out... (n00bie in the machinac world but can follow directions an diagrams
) but the somke freaked me out a lill Iv got another spree that runs good and it someks a little but not like that, any ideas or thoughts?
THANKS
THANKS
remove the air box, remove the carb, remove the intake thing that the carb is on. Then there is a little plastic holder thing with the reeds in it.Spiderlad wrote:Thanks for the replywhere are they at for future reference?
Thanks again
Sorry and Thanks
- Goped
Spree Compression
Both my 86 Spree's register around 90 PSI on my compression tester and both start easily and run fine. One has 2500 miles and the other about 1600. I have never had the head off of either one.
Re: Spree Compression
These tiny engines will give false reading form dead volume in some testers, the gauge that screws directly into the plug hole with no hose will be the most accurate.DENMANSHAFFER wrote:Both my 86 Spree's register around 90 PSI on my compression tester and both start easily and run fine. One has 2500 miles and the other about 1600. I have never had the head off of either one.
Old gas can cause it to smoke and run badly. If you did not drain the tank and fill with fresh gas you need to do that first and see what happens.
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
