cylinder gasket
floodgateus
cylinder gasket
Post by floodgateus »
I need a gasket for the cylinder to case gasket..they are way too much
to buy (shipping sucks)..can I use [u]formagasket?[/u]
FlooDGATEUS
Clivester
Post by Clivester »
Not a good idea. For a start, its important to keep the correct spacing between the cylinder and case since it effects port timing, displacement, and clearance of piston with cylinder head. If desperate, you would be better off buying high temperature sheet gasket material from an auto parts store and cutting your own. I don't recall if 1/64 or 1/32" is the correct spec. Anyone?
By the way, I purchased a very inexpensive top end gasket set for my Elite LX, it was intended for european SA50 models, but the base gasket is the wrong shape, with narrower transfer ports. Looks a lot like its from an SB50 or Spree. Unfortunately I don't have an original gasket for these lying around. If anyone is willing to scan a Spree or SB50 gasket against graph paper and post here or email me an attachment, I'd be willing to check it and pass on the information about the cheap set if it works. The aluminum head gasket in the set is spot-on.
Clive.
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
Post by Kenny_McCormic »
Buy one, you can not use form a gasket for this, too precise.
Elite LX gasket issue: DIO gasket?
Clivester
Post by Clivester »
Kenny_McCormic wrote: Elite LX gasket issue: DIO gasket?
Not a Dio gasket. Dios have larger port cut-outs than the LX. These are smaller more like a Vision (but smaller boost port) or SB50 or Spree.
My point is if the set is the same as either the SB50 or Spree this would be a very cheap alternative (about $8 shipped for head, base, exhaust, reed cage, manifold gaskets) for some forum members.
Clive. :wink:
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
floodgateus
So is there a site where I can print a full size picture of the gasket, then transfer it to gasket material, trace and cut?
No there isnt, buy one from a honda powersports dealer.
Or make your own from gasket paper.
evilone
Post by evilone »
Maybe I missed it but what motor do you need gasket for? I have an extra 87 elite se50 gasket.
DorkoElite303
Post by DorkoElite303 »
Spammer???????
hondadirtracer
Post by hondadirtracer »
yup. stupid spambots.
1987 Spree. Motor is in a rubermaid container.
1979 Honda Express that runs like a top.
Dac
Post by Dac »
DorkoElite303 wrote:Spammer???????
hondadirtracer wrote:yup. stupid spambots.
Im working with Noiseguy (the admin) to stop these spam bots.
Seems there starting to make there way though the register. I go thought all delete all the post, then NoiseGuy Deletes them.
This hole spam thing should be over in a few weeks, dont let them bother you.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
