New guy here. 94' SA50 (Elite SR). $100.00, 1700 miles, black with (ugh) purple rims. Runs perfect.
I've been riding for over 30 years, just not on scooters.
So my question - How do you change/drain the oil from the tranny? I've looked the scoot over and can't find a drain bolt anywhere.
Do you just warm up the scoot, pop out the filler bolt, and then lay it on it's side? Seems silly to me. No mention of anything in the Honda manuals (service/owners) about changing this oil. They just say "check it now and then."
Any help appreciated - More questions to come - Scootah!
p.s. I did a search - No luck.
Tranny oil change - How?
scootah wrote:Thank you Hondaman. Still seems silly. How much more would it have cost to add a drain bolt?? Doh!!
Drill the bottom of the case, bake the oil out(thiswill require FULL disassembly of the engine), find a welder with enough experience to weld cast aluminum, weld in a short tube.
