Page 1 of 2
57mph top speed
Posted: Sat Aug 23, 2008 4:15 pm
by nparks
Is this good for having a 28mm carb, 72cc kit and an exhaust?
+7.5:1 gears
Posted: Sat Aug 23, 2008 4:24 pm
by Kenny_McCormic
Yes, get some gears.
Posted: Sat Aug 23, 2008 9:11 pm
by DorkoElite303
Doing alot better then me. My top speed with out the gears is 52mph. But then agian...I'm in the mile high city.
Posted: Sat Aug 23, 2008 10:11 pm
by gobucks
does it have a after market variator?
Posted: Sun Aug 24, 2008 12:32 am
by nparks
gobucks wrote:does it have a after market variator?
No, but I do have 7.5:1 gears.
Posted: Sun Aug 24, 2008 12:57 am
by Kenny_McCormic
Get a AM vari and a set of weights, Im pretty sure 70+ is what you should be hitting with that setup.
Posted: Sun Aug 24, 2008 1:38 am
by Dac
Kenny_McCormic wrote:Get a AM vari and a set of weights, Im pretty sure 70+ is what you should be hitting with that setup.
an "AM vari" ? whats that?
a highspeed pulley in general would help. But i dont think that a pulley alone it going to jump his top end upwords of 70. But i do believe that set should pull like 65mph. Im not sure at this point. Call and talk to VT cycles. they might have some tuning advice.
Posted: Sun Aug 24, 2008 1:46 am
by Kenny_McCormic
AM=After Market
vari=variator.
Posted: Sun Aug 24, 2008 2:10 am
by Dac
Kenny_McCormic wrote:AM=After Market
vari=variator.
oh AM= after market, i should have known that.
i just failed like this guy...
Posted: Sun Aug 24, 2008 4:26 am
by ALOW1
Dac wrote:Kenny_McCormic wrote:AM=After Market
vari=variator.
That right there is funny.
Posted: Sun Aug 24, 2008 10:37 am
by nparks
Wow... how the * do you slide on your face like that? That could be a sweet dance move haha... Might be because his center of gravity is off due to being 4ft tall.
Posted: Sun Aug 24, 2008 12:08 pm
by burnt_toast
where are you getting your 57mph reading from? and under what conditions? flatout/downhill/with or against wind/temp
I'd say mid 60 is likely with that setup dialed in
Posted: Sun Aug 24, 2008 3:13 pm
by DorkoElite303
OUCH!!!!....worst case of rug burn.
Anywho ... with 7.5:1 gears you should be doing a lot better then that. What are you other tranny mods???
Posted: Sun Aug 24, 2008 11:20 pm
by Johnny5
Oh! Face burn
Posted: Mon Aug 25, 2008 12:30 am
by tru72
i have 8.5 in my 72cc and i stil do 72.. you jus need some more tweaking with it and im sure you can get more out of it!
aloha
D
