Spree - How fast is too fast?
Posted: Mon Aug 25, 2008 7:29 am
by GIJoeBob
My Spree is running better than ever now. It used to top out around 28 but now it is around 32 and sometimes it gets up to around 35. Once or twice it went past 35 and was screaming like a jet engine at which point I backed it down.
Just how fast is too fast for these little bikes?
Posted: Mon Aug 25, 2008 7:33 am
by EvilCrayon
mine tops out at 29mph. this sucks.
Posted: Mon Aug 25, 2008 9:11 am
by keithw
The limit with stock gearing is the engine rpm. I've had mine up to between 11,000 and 12,000 rpm. Stock the engine speed at 25 is about 8,000 rpm. If you are running at the higher rpm make sure and check your jetting. Go up step at a time with the main jet till it starts four stroking then back off one. If you can pull the higher revs it's time to look into a 1/2" belt, pulley mod, or bigger rear tire. That will push the rpm down and raise the speed.
keithw
Posted: Mon Aug 25, 2008 12:20 pm
by burnt_toast
"too fast?" never heard such a phrase..
Posted: Mon Aug 25, 2008 12:58 pm
by keithw
More is better, too much is about right.
keithw
Posted: Mon Aug 25, 2008 2:01 pm
by Kenny_McCormic
too lean? They really do scream before the piston is blown out the exhaust as a liquid.
Posted: Mon Aug 25, 2008 10:35 pm
by lipskid
When your face starts to melt...you're going too fast.
Posted: Sat Sep 13, 2008 5:56 pm
by Miller1155
No such thing as too fast...
Posted: Mon Sep 15, 2008 10:40 pm
by PimpinSpree
ive had mine going 50+ but that really has nothing to do with this thread due to my mods
aa
Posted: Mon Sep 22, 2008 9:32 pm
by DIOSpeedDemon
aa
Posted: Mon Sep 22, 2008 10:19 pm
by DorkoElite303
dio speed DEMON!!!! The marker of all those youtube videos! Hahaha...how is that stroker going???
Posted: Mon Sep 22, 2008 11:22 pm
by PimpinSpree
i learned how to put clutch springs on thanks to his video
screw that sob to a board and use an awl
Posted: Mon Sep 22, 2008 11:23 pm
by PimpinSpree
speaking of this topic, is there a way to do a front disc conversion?
Posted: Wed Sep 24, 2008 7:45 pm
by EvilCrayon
I hit 40mph on my 86 spree before the engine backfired, a huge stream of fire came out the back, and then my petcock broke.
need to find a new one or create a vacuum shut off.
Posted: Thu Sep 25, 2008 8:29 am
by keithw
40 mph is about 12,000 rpm. The Spree engine is speced for 8,000. They seem to handle 10,000 with a proper exhaust. It looks like they run lean or at least hot with a drilled stock pipe at high rpm. That flame was molten aluminum from the piston?
keithw
