Need help with pullys
e_kmiec23
Post by e_kmiec23 »
Hey I am trying to get into the crankcase on a Spree. I do not have a air gun just basic hand tools and a pully puller. How can I get the bolts off so I can open this thing up to see what the damage is? Thanks for any help guys! :D
Eddie Kmiec
da808fokai
Post by da808fokai »
Airgun isnt needed, although helpful at times... To get into the case remove all the 8mm bolts. If it has never been opened before (which I doubt is the case) you may have to tap it a bit to get it loose.
Once open you can use a screwdriver to wedge the front pulley while removing the front nut (14mm?). I use a belt wrench to remove the back pulley, although you can buy or make a 2 pin adjustable wrench to hold the rear clutch while removing the rear nut.
Goodluck.
Post by Kenny_McCormic »
You could use a strap wrench to hold it.
e_kmiec23
Post by e_kmiec23 »
Thanks for the help guys! I will try it and see what happens. I will let you know if I need any other help. Thanks again
Eddie Kmiec
e_kmiec23
Post by e_kmiec23 »
Thank you..it worked the first time with the rubber wrench. Also does it look like I need to replace the clutch or just the 3 little arms. Sorry about the picture...its off a camera phone.[img][img]http://i387.photobucket.com/albums/oo31 ... 3/bike.jpg[/img][/img]
Eddie Kmiec
Those pads look pretty thin to me, I would replace.
e_kmiec23
Post by e_kmiec23 »
Where can I find the pads at and is it just the three pads on the arms that I am getting? Dont know too much about this stuff. Is there anything performance wiss I should do while I am in there any info would be great! Thanks again guys!
Eddie Kmiec
brad_659
Post by brad_659 »
i am at the exact same step in this process...and i need some pads or a whole new clutch if there are any guys out there with a clutch PM me with a price.
A honda motorcycle/dirtbike dealer can probably get the pads.
