spark plug
Posted: Fri Aug 29, 2008 4:15 pm
by Diesel Spree
hey im running the stock plug in my 86 spree it is a nkg bpr6hs and i read some where that if u run the extended high speed riding plug it makes it go faster it is a bpr8hs is this true or just a sails pitch and are there performance plugs for these and do they even work?
Posted: Fri Aug 29, 2008 4:55 pm
by EvilCrayon
I didn't notice a difference.
Posted: Fri Aug 29, 2008 5:21 pm
by justinnielsen01
8 will make your head temp cooler
Posted: Fri Aug 29, 2008 5:59 pm
An BPR8HSA is what is called for in the manual for extended high speed riding. A BPR4HSA is called for in colder climates, 41° and below.
Posted: Sat Aug 30, 2008 10:29 am
by Diesel Spree
so no one thinks it makes a defferance it just makes the head cooler
thanks
Posted: Sat Aug 30, 2008 12:00 pm
Diesel Spree wrote:so no one thinks it makes a defferance it just makes the head cooler
thanks
Which increases longevity.
Posted: Mon Sep 01, 2008 7:31 pm
by Diesel Spree
ok thanks
spark plug
Posted: Mon Sep 01, 2008 9:28 pm
by needfasterthan31
i just bought the high speed spark plug at my local autoparts store for $1.99,they had to call there warehouse and had it the same day in a few hours,if you have a owners manual it will show you the cold temperature plugs,normal condition plug,and the high speed plug numbers.or you can buy a high speed same identical plug off a seller on ebay for $6.50
