gas leak
Posted: Sun Aug 31, 2008 3:33 pm
by mkp85
I just got a 85 spree and just put gas in it and its leaking out the carb pretty good when running and out the bottom of the gas tank where the hoses connect. whats wrong?
Posted: Sun Aug 31, 2008 3:55 pm
by WillyPhister
Make sure your petcock is in there tight, replace your fuel lines if they are old and cracked, check the lower screw under the high speed needle and make sure its tight and not loose, its the carb drain screw and its a flat head.
petcock
Posted: Sun Aug 31, 2008 4:11 pm
by mkp85
whats the petcock?
Posted: Sun Aug 31, 2008 4:44 pm
by mkp85
never mind figured that out and tightened everything. it only leaks out the carb after it runs and constantly drips in the petcock area. Must be a whole or something.
