Muffler 'ruined' - which would be easier.
Saltisall
Post by Saltisall »
Last week I drilled a 3/8 inch hole in the first baffle of my muffler (87 spree non-Iowa)
I don't mind the louder sound, as it gained a few miles an hour. However my girlfriend (THE SCOOTERS OWNER) hates it....a lot.... doesn't even want to ride it any more.
So I need advice, would be be easier to find a replacement and swap ou (I've already posted in the parts forum)
Or have someone cut the thing open and weld a bit of metal over the hole I've created?
Please help if you can.
Post by Kenny_McCormic »
Cut n weld is easy with a cutoff wheel and a wire welder.
DJPhatman
Post by DJPhatman »
If you reached it with a drill bit, you can reach it with a self-tapping screw. Get one at just about any hardware store, coat the threads and bottom of the head with high temperature RTV, screw it in the hole you drilled, and let it sit overnight. The hole is gone, and it's easily reversible, in case she is gone! :lol:
keithw
Post by keithw »
Getting a screw through the outlet pipe could be a challenge. I'm not sure that the head of a 3/8" screw would fit. Check out my post about my Spree test bed. I've got pictures of a cut open muffler from when I welded up one that had been drilled.
keithw
Honda Spree, 1985.
Another Honda Pal
jeffros105
Post by jeffros105 »
or look for a new girl friend
1962 Honda Cub 50 C100
1963 Honda Super Cub C105
1966 Cub 50 C50
1970 Honda CL 70
1985 Honda Spree
2006 Sachs Madass
Ziraya
Post by Ziraya »
earplugs, cheapest and easiest
Ziraya wrote:earplugs, cheapest and easiest
Full face helmet doubles as sound protection.
Corey
Post by Corey »
Loud Pipes Save Lives! and * off the neighbors! :D
maddog
Post by maddog »
Do a cut/splice with an elite-s pipe!
