jet size part #
Posted: Thu Sep 04, 2008 2:33 pm
by Corey
Stupid dealers aint smart enough to find any others jets other than 78 & 68.
Does anybody got part #s for some jets that i should have on hand?
Posted: Thu Sep 04, 2008 3:10 pm
by Clivester
Posted: Thu Sep 04, 2008 3:15 pm
by Corey
so im goin to have to drill it out?
Posted: Thu Sep 04, 2008 3:51 pm
by Clivester
Corey wrote:so im goin to have to drill it out?
There's a few here with the HON-99101-187- prefix
http://www.m-and-d.com/siteindex367.html
Also see this thread:
http://hondaspree.net/phpBB2/viewtopic. ... 2a3ff9cff2
Otherwise you will need to buy some micro/jewelers/oxy torch drills from eBay to drill yourself.
Here's a chart, but only covers larger sizes:
Width------Keihin # -- DynoJet # --- Mikuni #
0.0350---- 92.5--------- 92----------- 86.3
0.0360---- 95----------- 94----------- 88.1
0.0370---- 97.5--------- 96----------- 90.0
0.0380---- 100---------- 98----------- 91.9
0.0390---- 102.5------- 100---------- 93.8
0.0400---- 105--------- 102---------- 95.6
0.0410---- 107.5------- 104---------- 97.5
0.0420---- 110--------- 106---------- 99.4
0.0430---- 112.5------- 108--------- 101.3
0.0440---- 115--------- 110--------- 103.1
0.0450---- 117.5------- 112--------- 105.0
0.0460---- 120--------- 114--------- 106.9
0.0470---- 122.5------- 116--------- 108.8
0.0480---- 125--------- 118--------- 110.6
0.0490---- 127.5------- 120--------- 112.5
0.0500---- 130--------- 122--------- 114.4
0.0510---- 132.5------- 124--------- 116.3
0.0520---- 135--------- 126--------- 118.1
0.0530---- 137.5------- 128--------- 120.0
0.0540---- 140--------- 130--------- 121.9
0.0550---- 142.5------- 132--------- 123.8
0.0560---- 145--------- 134--------- 125.6
0.0570---- 147.5------- 136--------- 127.5
0.0580---- 150--------- 138--------- 129.4
0.0590---- 152.5------- 140--------- 131.3
0.0600---- 155--------- 142--------- 133.1
0.0610---- 157.5------- 144--------- 135.0
0.0620---- 160--------- 146--------- 136.9
0.0630---- 162.5------- 148--------- 138.8
0.0640---- 165--------- 150--------- 140.6
0.0650---- 167.5------- 152--------- 142.5
0.0660---- 170--------- 154--------- 144.4
0.0670---- 172.5------- 156--------- 146.3
0.0680---- 175--------- 158--------- 148.1
0.0690---- 177.5------- 160--------- 150.0
0.0700---- 180--------- 162--------- 151.9
0.0710---- 182.5------- 164--------- 153.8
0.0720---- 185--------- 166--------- 155.6
0.0730---- 187.5------- 168--------- 157.5
0.0740---- 190--------- 170--------- 159.4
0.0750---- 192.5------- 172--------- 161.3
0.0760---- 195--------- 174--------- 163.1
0.0770---- 197.5------- 176--------- 165.0
0.0780---- 200--------- 178--------- 166.9
0.0790---- 202.5------- 180--------- 168.8
0.0800---- 205--------- 182--------- 170.6
0.0810---- 207.5------- 184--------- 172.5
0.0820---- 210--------- 186--------- 174.4
0.0830---- 212.5------- 188--------- 176.3
0.0840---- 215--------- 190--------- 178.1
0.0850---- 217.5------- 192--------- 180.0
0.0860---- 220--------- 194--------- 181.9
0.0870---- 222.5------- 196--------- 183.7
0.0880---- 225--------- 198--------- 185.6
0.0890---- 227.5------- 200--------- 187.5
Clive.
by keithw
I posted the numbers for 63, 65, 68, 70, 75, 80, and 85 not long ago but I can't seem to find the post. Hopefully someone better than I with the search tool can find it.
keithw
Posted: Thu Sep 04, 2008 4:52 pm
keithw,
One of the links Clivester posted is where you put the jet part numbers.
--- pasted in for convenience - keith's jet info ---
62 99101-ZG00620
65 99101-187-0650
68 99112-GHB-0680
70 99101-1870700
75 99101-1870750
80 99101-187-0800
85 99101-1870850
Posted: Thu Sep 04, 2008 5:38 pm
by keithw
thanks, I hated to think of typing it in again. I haven't found any over 85. I did find some nice metric drill sets on ebay. They are in .05mm steps up to 2mm as I recall. I measured them and they were accurate and drilled nice holes. Reasonably priced also.
keithw
Posted: Thu Sep 04, 2008 6:08 pm
by Kenny_McCormic
If a jet is bored to big one could theoretically fill the hole in with solder and rebore it.
Posted: Thu Sep 04, 2008 10:36 pm
by gobucks
are the part numbers previously mentioned for jets for an elite, or are they just for a spree?
Posted: Thu Sep 04, 2008 11:24 pm
by darat
ok if you can find jets for the elite then they will fit the spree. pretty much the same carb.
