Lots of smokey exhaust
gobucks
Post by gobucks »
My elite smokes a lot at start up, i'm running gn2 in it, is this normal?
Post by Kenny_McCormic »
Cold engines smoke, fact of life. Could be a bad crank seal on your oil pump if it gets worse after sitting a few weeks.
Elite1998
Post by Elite1998 »
I don't think its anything to worry about.
On a cold start if your really pushing out smoke and lacking power for a short time I consider that normal on 2-strokes and if it get better within a time frame of 15 seconds to 30 seconds your fine..if its longer than that it may be something to start worrying about.
But mine does the same thing as do 2 stroke snowmobiles.
Honda Elite SA50-S
Stock motor, 9:1 gears, Kelli High speed pulley=a top speed of ?? Maxed the speedo out if that counts..average 45 mph
average 85 mpg
burnt_toast
Post by burnt_toast »
yup you WANT smoke on startup on a 2stroke, its a good sign. should clear once warmed up
projects galore :nerd:
