money to blow on elite.
vette76
Post by vette76 »
any ideas?
87' spree (SOLD
12' wrx
vette76
Post by vette76 »
i would appreciate any links on where to find this stuff. its suprisingly hard to find.
87' spree (SOLD
12' wrx
burnt_toast
Post by burnt_toast »
general speed up parts should be your best bet. easier and cheaper to find than bigger things. But it all depends on your budget.. good luck!
projects galore :nerd:
vette76
Post by vette76 »
it would be cheaper. on the other hand how much can i really get out of it.
87' spree (SOLD
12' wrx
What year is yours again? '87?
Get with Diolijah about parts for that. There are oversize jugs and pipes available for the '87 - 93 Elites. I'd be tempted to do a jug/variator/exhaust upgrade.
We should get a list of parts together available for these Elites and get it posted.
vette76
Post by vette76 »
mine is an 89. the probllem i am running into is it is an sb model. no variator. almost the same as the spree. they dont sell parts for it. only sa+se.
87' spree (SOLD
12' wrx
Does the SB exhaust out the front (like Spree) or out the side corner (like the 87-93 Elite?)
maddog
Post by maddog »
Ony one problem with thr pre 94 elites is they don't make final drive ratios along with the aeros. i can still get an 8 to 1 ratio for the aero but its not cheap and its the last one, an engine swap to the sa50 is the best way to gain speed cuz they have tons of parts for this engine and a basic stage one requires a 9 to 1 ratio among other tricks :lol:
vette76
Post by vette76 »
noiseguy wrote:Does the SB exhaust out the front (like Spree) or out the side corner (like the 87-93 Elite?)
exits out the front. like the spree.
87' spree (SOLD
12' wrx
Does the jug look identical to the Spree? The Spree has a tiny exhaust port (squished.) Sounds like the SB-50 is basically another Spree. I've never seen one.
If it has the big pulley, I'd try to fit up an Aero variator to it (if it'll fit.) That would get you top end and launch. We've talked about doing this before. PM me and we'll see if it can work. I have an '85 Aero variator on the shelf I can measure.
vette76
Post by vette76 »
from what i can see the jug looks similar. i will pull the side cover today and measure the shaft.
thanks noiseguy.
87' spree (SOLD
12' wrx
Gerris
Re: bookkeeping services near me
Post by Gerris »
maddog wrote: Wed Jul 20, 2005 10:56 pm Ony one problem with thr pre 94 elites is they don't make final drive ratios along with the aeros. i can still get an 8 to 1 ratio for the aero but its not cheap and its the last one, an engine swap to the sa50 is the best way to gain speed cuz they have tons of parts for this engine and a basic stage one requires a 9 to 1 ratio among other tricks :lol:
Yes, you definitely marked it
