center spring question!!
i got a Sym DD50 with:
-66cc bore
-Keli pulley
-SEF Ramp
-R1 Pipe
-8g weights
-7.4-1 gears
i want to upgrade my center spring and clutch springs for better bottom end...which ones should i go with??? someone told me to go with 1500rpm center spring and 2000rpm clutch springs...is that a good setup?? any suggestions??
-66cc bore
-Keli pulley
-SEF Ramp
-R1 Pipe
-8g weights
-7.4-1 gears
PimpinSpree
- burnt_toast
PimpinSpree
- burnt_toast
PimpinSpree
burnt_toast wrote:completely opposite.. more like running lighter weights. but overall springs and rollers control two areas of transmission shifting and balancing them is key.PimpinSpree wrote:so its sorta like changing to heavier weights on the variator?
for some reason i kept thinking heavier weights would shift slower, but now that i think about it. Lighter weights would have to be spinning faster to make the same momentum (or somthing to that effect) I have yet to start doing any tuning on the cvt.
we use a trans washer between the ramp & boss, this drops the belt on the front pulley and gives more toque off the line, you can also use shims, you can also use a center spring saver bearing which also helps to dial in the trans just right ! i use both
DorkoElite303
OH MAN! I should have thought of this before! How big shims you using? Any pics?maddog wrote:we use a trans washer between the ramp & boss, this drops the belt on the front pulley and gives more toque off the line, you can also use shims, you can also use a center spring saver bearing which also helps to dial in the trans just right ! i use both
PimpinSpree
