i only get 25 miles on 1 tank of gas
what i only get 25 miles on a tank of gass i know its 50 mpg but still this thing is small how do i get more
please help
1) Check that your airfilter and exhaust are clean. Check carbon on head and get a clean plug.
2) Check your main jet, should be #65
3) Check your needle jet position, should be at nominal (which is the forth position from the top.)
I get this question a lot, this is going in tech docs. You should be getting close to 50 miles per tank. That's closer to 100 MPG.
Admin, Hondaspree.net
