elite rims
elite rims
hey i have a 94 elite. just wanted to know if anyone knows of any other rims available for them so your not stuck with boring looking white rims, i can paint them but i want something totally different like a chrome or aluminum rim.
DorkoElite303
YES!!!! There are the sexy JDM rims. for the real honda dio zx.
Red
JDM GOLD!!!!!
Gunmetal
But guess how much a set is going to run you????
$50?
$100?
$200?
NOPE WRONG!
$400!!!
There are some knock off ones for about....150 a set? I saw them on ebay. Also...JDM rims are front disc brakes...so you can only use the back wheel. Unless you do the disc brake conversion.
Now for the porno graphic material.
Another Dio Style
Daytona! You need a hub to fit these bad boys on.
Red
JDM GOLD!!!!!
Gunmetal
$50?
$100?
$200?
NOPE WRONG!
$400!!!
Another Dio Style
DorkoElite303
you will find more info Here. But a fare waring, the site im linking you is nothing but bad grammar and bad spelling. But! i do see rims and disk brake setups on there time to time, you will have better luck there.
But dont think its going to be a cheap slap together, its going to cost you some major money for some different style rims.
Also, welcome to this site.
This site is much more information based then the one im linking you. That forum is more of a chit chat place. this forum is all about helping you to build the best bike you can.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
cool
72cc bore kit, 28mm oko carb, gears(not sure what the previous owner couldn't remember)and a pipe (think is a V8 pipe) the name plate is missing..has a 1500 spring and a variator and springs and weights in it already, didnt check exactly what sizes are in it though. ive gotten it to almost 60mph so far.
we where just talking about that here...
http://www.hondaspree.net/phpBB2/viewtopic.php?t=7175
DorkoElite303
To answer you question about the disc brake conversion... It's a chop and weld thing.
What most of the guys in hawaii do is get a chopped up front end of a "dio" and weld it on to their set-up. I've seen other use a different make and model for their donor bike and chop and weld.
All in all...you can't just swap the front forks and stem into your elite.
