85 honda spree
- generalsecord
- BMX
85 honda spree
no matter what i do i cant get the spree to idle normal.its running at about 60,and then quits i have tried everthing.need help
thanks
george
thanks
george
- generalsecord
- BMX
85 honda spree
spree runs at a high idle.cant get the idle down.the adjustment screws dont seem to make any difference.when i start it up it takes off at high speed and then quits.when i stick my finger down insidethe air chamber i can get it to run normal,but the minute i take my finger away it starts going back to the high idle and then quits.need help
thanks
george
thanks
george
- generalsecord
- BMX
honda spree
yes the air box is hooked up.i put the new air filter in and the cover on and now it wont start.it just cranks on.still need help
george
george
- generalsecord
- BMX
honda spree
no i cleaned the carb,but maybe i will clean it again.it doesnt matter what i do with the idle screw or fuel mixingscrew.
You have a bad oring on the bystarter. Replace the oring and it will idle fine. Check my post on testing the bystarter vacuum and if that works you know 100% its the oring on the bystarter.
Main needle does nothing if the bike is at idle. Idle enriching circuit and the bystarter are the key to idle once the scooter gets warmed up.
If the little hole in the bowl is open to allow gas into the bystarter enriching circuit/needle than what you have is a vaccum leak around the bystarter to the outside air.
Jeremy Ferch
- generalsecord
- BMX
85 honda spree
i cant find ferchja's post on testing vacumn testing the bystarter.can you please help me.find it.
http://www.hondaspree.net/modules.php?n ... tarter[url][/url]
It's in this post go about 2/3rds down the page. You'll see it.
Jeremy Ferch
