Specific Fuel Line Tube Diameter?
Posted: Tue Sep 30, 2008 2:38 am
by Remy
I'm about to replace my old rusty tank with a clean replacement, and figured I might as well replace the clogged fuel lines as well. I did a search and could not find a direct answer as to whether or not there is a specific diameter for the fuel line tubes? Can I just grab any arbitrary hoses from Home Depot or should I use a designated automotive line? I'm not trying to get overly cerebral about the whole thing, just want to do it right the first time through. Thanks.
Posted: Tue Sep 30, 2008 12:01 pm
by devenex
Just take the line off and take it with you to an auto parts store. They can size it for you there and cut you the length needed.
I did this with my vacuum hose and it was about 69 cents to replace.
