variator pulley...
SprEE*MP*
variator pulley...
Post by SprEE*MP* »
Why wont the front variator pulley of a dio or other, fit in a spree?
-1984 Spree,
Clivester
Post by Clivester »
The crankshaft has a different profile.
Clive.
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
SprEE*MP*
Post by SprEE*MP* »
bigger or smaller?
-1984 Spree,
Post by Kenny_McCormic »
Its all different, best way would be to design and machine a new one, several have discussed this, none have attempted yet.
SprEE*MP*
Post by SprEE*MP* »
SOMEBODY DO IT!!!!!!!
-1984 Spree,
devenex
Post by devenex »
What about the elites that basically have spree engines?
Don't they have variable pulleys? And if so, shouldn't the crank fit in a spree engine?
1986 Spree w/ '87 SE50 motor
Dac
Post by Dac »
devenex wrote:What about the elites that basically have spree engines?
oh dude! the Pal!
i totally forgot about that.
dude, someone just has to tear apart a pal variator and see if it will fit in a spree. if it dose, thats going to break some huge ground.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
keithw
Post by keithw »
BTDT, I've got a Pal and a Spree both. The Pal pulley doesn't fit the Spree. The crankshaft end is different. If you could find an entire Pal engine it should bolt right in.
I haven't torn them apart to mix and match the parts but I think the crankshaft and the side cover would need to be swapped.
The Pal is still a moped class scooter, 25-30 mph top end. What the variable pulley gets you is more pull off the line.
keithw
Honda Spree, 1985.
Another Honda Pal
devenex
Post by devenex »
Well if you get more pull off the line, then you can do a pulley mod and have a more normal pull at the start with a higher top end, right?
EDIT: Granted your not going to hit 50mph or anything, but you should approach 35mph, which actually makes a difference going around town.
Dac
Post by Dac »
devenex wrote:Well if you get more pull off the line, then you can do a pulley mod and have a more normal pull at the start with a higher top end, right?
yeah but if it requires to tear apart the block, get a new crank and a pulley for a bike that is hard to find, why not just get a good motor and build that up.
i mean, dont get me wrong im all about making the spree faster, but thats just unrealistic.
keithw
Post by keithw »
Yes, I modified the pulley on my Pal. With that and the engine mods I have seen 45 mph. Normally about 40, still fiddling with it.
Just picked up a second Pal today. we'll see how that one goes.
keithw
Honda Spree, 1985.
Another Honda Pal
burnt_toast
Post by burnt_toast »
do I really have to say it? :lol:
if you're going to swap something into a spree, make it worthwhile and go dio :twisted:
Unless you can find a PAL block dirt cheap, dio swap just makes more sense even for lower speeds.
projects galore :nerd:
SprEE*MP*
Post by SprEE*MP* »
Dio's are expensive
-1984 Spree,
keithw
Post by keithw »
Pals are miserably hard to find as they are JDM and only a hand full ever came to the states.
keithw
Honda Spree, 1985.
Another Honda Pal
Dac
Post by Dac »
keithw wrote:Pals are miserably hard to find as they are JDM and only a hand full ever came to the states.
keithw
yeah, finding a Pal would be harder then finding a dio by a long shot.
BTW Keithw, if you where ever to part out one of your pals you could sell the plastic alone for a good amount of money on the hawaii forums. i have seen a full pal body set go before and it was a few hundred.
