How Fast Can Dio's Go?
ALOW1
Post by ALOW1 »
How fast can a Dio motor make a Elite or Spree go?
tru72
Post by tru72 »
the fastest dio motor i know of was from a friend named Achi . he got a ticket going over 100mph on the hwy. He had 2 other guys with him. They all got tickets. The way they got busted was the airport tower saw 3 of them flying donw the hwy and called the popos! As for the size of motor, that remain to be unknown, but knowing him that had to be NOS!
aloha
D
veedubh20
Post by veedubh20 »
I had a spree w/ dio (w japan rear mini skirt panels and tail) The motor was built by tobatech, fully port motor :lol: ministroke /50mm bore- 88cc,keihin28mm carb,pg long, 6.8 gears.
the spree clock 80 mph is 110lbs rider.
we went 3 times run and hammer wide open throttle 3 miles runs, got no temp gauge :P :lol: by looking @ plug burns.
burnt_toast
Post by burnt_toast »
74.4 MPH Gps'd here on a 75cc Street tuned Elite, full race even faster!
projects galore :nerd:
Post by Kenny_McCormic »
Depends on the motor, WAY faster than a spree front end should be trusted at.
jstone
Post by jstone »
Doesn't it all depend on gearing? You would think in theory you could make one go well over 100 mph. The only thing would be how fast it gets there. I'm sure that there is a limit on how small you could go with gears, so the real question is how fast could a dio motor go with X gears in it. Then the challenge would be to produce a motor with the highest possible RPMS.
seacook
Post by seacook »
No way! Get out! My 84 Spree that I am happy when I see it reach 34 mph having the capability of reaching 100?
Allright, if it can be done, how about a parts list, cost and availability?
burnt_toast
seacook wrote:No way! Get out! My 84 Spree that I am happy when I see it reach 34 mph having the capability of reaching 100?
I'd estimate $1k for a budget build, for 80+mph out of dio in spree frame. Availability depends on who you know and who you can trust, as far parts..
jstone wrote:Doesn't it all depend on gearing? You would think in theory you could make one go well over 100 mph. The only thing would be how fast it gets there. I'm sure that there is a limit on how small you could go with gears, so the real question is how fast could a dio motor go with X gears in it. Then the challenge would be to produce a motor with the highest possible RPMS.
Top speed is a reflection of horsepower. If you have the horsepower to pull bigger gears then you will go faster with those gears. If your motor is against it's max rev limit (not rev limiter but a 2 stroke has a rev limit determined by how much air it can pump and even unloaded you can't rev past it) but you don't have the horsepower to go faster and put in bigger gears then you go slower.
steffen707
Post by steffen707 »
Yeah i was gunna say something like that. Just cuz the gears may allow x mph doesn't mean any engine can attain that mph.
What I want to know is, what is the max mph with stock 12.44:1 gears and max mph with 9:1 gears. Not if xyz motor combo can make that mph, but what could be reached with enough power.
TURN1
Post by TURN1 »
Aloha Spirit.
Pass on the ALOHA Spirit!!!
DorkoElite303
Post by DorkoElite303 »
Hahaha, Yeah Achi is into 4-stroke ruckus and metros now. He talks all the time on http://www.totalruckus.com.
He was talking about his 100mph Dio, and how much work he put into. He went above and beyond on every single part on that beast.
'07 Honda Goldwing 1800.
07' Honda CBR 600rr
'97 Honda Elite- parts bike
98' Honda Elite SA50 SR(85cc plus all bells and whistles)
00' Honda Elite SA50p S
83' Honda PAII (not running)
DorkoElite303
There is the real dio speed demon.
07' Honda CBR 600rr
veedubh20
Post by veedubh20 »
dont forget a parachute :lol: cant drag both foot onto a ground.
maddog
Post by maddog »
must be a local boy= instant blown crank bearings :lol:
