New Spree.. Need tips and advice
Posted: Wed Oct 01, 2008 5:34 pm
by Mowped
Hi there, I just got a spree with about 5000 miles for about $50 from a friend.
Cleaned the carb, new tires and new battery. But now there's a problem with the new tires. I put on tires that were a little wider than the previous ones and now the kickstand is always hitting up against the wheel. Should I just take the kickstand off and grind it a little? or should I keep it off and find a side kickstand?
Also I'm thinking about painting it, what's some prep work on the plastic I need to do? Should I prime it first?
Thanks.
Posted: Wed Oct 01, 2008 6:57 pm
by Kenny_McCormic
Get 2.5x10 tires
Posted: Thu Oct 02, 2008 12:33 am
by devenex
Well if you cant exchange the tires, either of the options you named would work fine (so long as the kickstand is all the tires are rubbing).
The cheapest option is probably to tweak the stock stand if only a little clearance is needed.
Posted: Thu Oct 02, 2008 3:31 pm
by Mowped
well i think im gonna keep the 2.75x10 tires.. can take corners faster :D, so i might just try to grind a bit off the kickstand...
Posted: Fri Oct 03, 2008 2:29 am
by DoubleAey
yeah, thats what i would do too. painting plastics is kind of easy too. just make sure to clean them, sand it down a bit. no need to prime. get the spray paint especially made for plastic paint too, like from wal mart. they have a good brand there. also, when painting, do light layers. the more layers, the more glossy. if you over spray, you can tell, so thats why you do light layers.
Posted: Fri Oct 03, 2008 8:11 pm
by PimpinSpree
priming most deffinitly is needed, i would also get a can of adhesion promoter (wal-mart carries it) Nothing makes a paint job worse than it flaking off
Posted: Wed Oct 29, 2008 11:55 am
by scooter trash
I didnt prime my scoot and it still looks great after about a year of wear. i used Krylon's fusion plastic spray paint
