oil light when leaning?
Posted: Wed Oct 01, 2008 5:44 pm
by DoubleAey
it seems that everytime i lean the spree to the left and sometimes to the right, my oil light turns on. and everytime its straight up it turns off. OR, when i have it on its stand, it goes on... loose sensor maybe? i dont even know where to check for it...
Posted: Wed Oct 01, 2008 5:53 pm
by EvilCrayon
it's normal. have you tried topping it off with oil and then doing the same? it shouldn't go on.
Posted: Wed Oct 01, 2008 6:35 pm
by DoubleAey
oh!? this is normal!?!??! thats good news. yeah, ill probably try doing that, that might/probably would fix the problem. i never even thought of that! then again, my oil level used to be lower i think, and it never went on. well i think that might work, cause its not full at the moment.
Posted: Wed Oct 01, 2008 6:58 pm
by Kenny_McCormic
check the level, 2 stroke engines eat their oil, only fill it with Honda GN2.
Posted: Wed Oct 01, 2008 7:35 pm
by DoubleAey
yeah, i know. and thats the only oil i will use for these scooters. i had taken out the old 2 stroke oil that came with the scooter about a week ago and put the honda one in.
Posted: Wed Oct 01, 2008 7:43 pm
by Dac
there is two wires going to the oil container. one of them could be loose. or it could just be starting to get low.
