85 spree RUNNING CHOPPY
please need help, it runs for a minute or two down the block but has bad idle and runs choppy then shuts down
oh it only has 980 miles on it
.......And check the gas flow from the petcock. If you wait 20 minutes or so then it runs again for a while and shuts down you may not have enough gas flow because of a bad petcock or blocked filter.
Clive.
Clive.
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
Guys, lay off the plug chops. Plug chops are only really critical on non-stock scooters. Most people don't do them right anyway, so let's start with the basics.
Sounds like the bystarter is closing up after 30 seconds (by design) and once it does, your scoot quits running. I think it's most likely that your carb is dirty, which is the root cause of at least 50% of the problems we see here.
Admin, Hondaspree.net
Arnadanoob
I will agree here. Plug chopping is not necessary unless it's a performance tuning measure which isn't the case here based on what the OP posted.noiseguy wrote:Guys, lay off the plug chops. Plug chops are only really critical on non-stock scooters. Most people don't do them right anyway, so let's start with the basics.
Keep in mind that cleaning the carb doesn't mean merely spraying it into the carb while it's still on the bike with everything connected to it. The correct way to do this is to remove it, take it off the bike, remove all rubber seals/plastics that may not take well to the solvent, disassemble the carb (have an experienced person help you if you never did this before), remove the bystarter (electric choke) then start spraying into all the little holes and tubes. Make sure you spray with the throttle valve closed, partially opened, and full WOT, then chase it all down with high pressure air and blow through all those little holes. Clean the inside of your fuel bowl, if it's lined with slimy stuff clean all that stuff out, that's the fuel going bad.
If you can trace the fuel line, look for your inline fuel filter and change it with a new one, it doesn't cost much. If it's one of those clear filters, check to see if you have a lot of crap going into it, if there's a lot of junk in there like rust flakes, that's a sign that your tank may need to be cleaned/purged.
Reliable and dependable tuning from 15+ years of experience.
KENNY!!!!! are you seeing this kenny????Arnadanoob wrote:I will agree here. Plug chopping is not necessary unless it's a performance tuning measure which isn't the case here based on what the OP posted.noiseguy wrote:Guys, lay off the plug chops. Plug chops are only really critical on non-stock scooters. Most people don't do them right anyway, so let's start with the basics.
Kenny_McPlugChop im talking to you! read this!
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
MotorMaker
- Goped
Not really, it can tell you whats up in an extreme carb issue and its peace of mind once it seems to be running right.Arnadanoob wrote:I will agree here. Plug chopping is not necessary unless it's a performance tuning measure which isn't the case here based on what the OP posted.noiseguy wrote:Guys, lay off the plug chops. Plug chops are only really critical on non-stock scooters. Most people don't do them right anyway, so let's start with the basics.
